Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Traduciendo paso 1
Paso 1
Use a thin pry tool or tweezers to carefully pry up and disconnect the upper coaxial cable connector from the logic board.
- | [* black] Use a thin pry tool or tweezers to carefully pry up and disconnect the upper coaxial cable connector from the logic board. |
+ | [* black] Use a thin pry tool or [product|IF145-020|tweezers] to carefully pry up and disconnect the upper coaxial cable connector from the logic board. |
[* icon_note] There are two coaxial connectors in close proximity. Disconnect the one nearest the battery connector. | |
[* icon_reminder] During reassembly, this can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat of your spudger. The connector should snap into place. |
