Saltar al contenido principal
Sustitución de la Batería del iPod Touch 2ª Generation
Inglés
Español
Paso 4
iPod Touch 2nd Generation Battery Replacement: paso 0, imagen 1 de 3 iPod Touch 2nd Generation Battery Replacement: paso 0, imagen 2 de 3 iPod Touch 2nd Generation Battery Replacement: paso 0, imagen 3 de 3
  • The battery on the second generation Touch is attached via solder pads with small holes that go through the battery ribbon cable and attach to flat pads on the face of the logic board. In this step, you will heat each solder pad individually while using a metal spudger to pry it up from the logic board.
  • DO NOT bridge the connection between the solder pads both on the board and on the ribbon cable with your spudger. Shorts have the potential to ruin the logic board.
  • Beware of overheating the board and the cable. Only hold the tip of the iron against the pad long enough to let the solder melt. Excess heat buildup has the potential to ruin the logic board or melt the ribbon cable.
  • Start working from one side of the battery ribbon cable. In our case, we started on the left. Heat the leftmost solder pad while gently prying up from under the ribbon cable to free it from the board. Repeat this process for each of the two remaining pads, working either right to left or left to right.
La batería se conecta a través de almohadillas de soldadura con pequeños orificios que atraviesan el cable plano de la batería y se conectan a las almohadillas planas en la parte frontal de la placa lógica. En este paso, calentarás cada almohadilla de soldadura individualmente mientras usas un spudger de metal para sacarlo de la placa lógica.
NO puentees la conexión entre las almohadillas de soldadura tanto en la placa como en el cable plano con tu spudger. Los cortocircuitos tienen el potencial de arruinar la placa lógica.
Cuidado con el sobrecalentamiento de la placa y el cable. Solo sostén la punta del soldador contra la almohadilla el tiempo suficiente para que la soldadura se derrita. La acumulación excesiva de calor tiene el potencial de arruinar la placa lógica o derretir el cable plano.
Comienza a trabajar desde un lado del cable plano de la batería. En nuestro caso, empezamos por la izquierda. Calienta la almohadilla de soldadura más a la izquierda mientras haces palanca suavemente desde debajo del cable plano para liberarlo de la placa. Repite este proceso para cada una de las dos almohadillas restantes.
