Saltar al contenido principal
Dell u3014 monitor repair. Power on problem.
Inglés
Español
Traduciendo paso 1
Paso 1
Dell u3014 monitor  repair. Power on problem., Removing bezel: paso 0, imagen 1 de 2 Dell u3014 monitor  repair. Power on problem., Removing bezel: paso 0, imagen 2 de 2
Removing bezel
  • The u3014 monitor opens the same as most other recent Dell monitors.
  • First remove the stand.
  • Remove the bezel. This can be done by hand and a plastic knife. Approaching the screen from behind, peel the bezel with your fingers (photo).
  • The rest follows quite easily, but in the corners you might need to insert a blade or similar to pry open the clips.
  • When removing the bezel, be careful with the control panel (stuck in place with glue, covered with glued-on strip) and power-button (2 screws).
Insertar traducción aquí
