Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Paso 10
Remove the following screws securing the logic board to the rear case:
  • Remove the following screws securing the logic board to the rear case:
  • Two 2.3 mm Phillips screws
  • Two 2.7 mm standoff screws
  • Standoff screws are best removed using a standoff screwdriver or bit.
  • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  • One non-magnetic 2.7 mm standoff screw
  • Be sure to put this screw back in its original position at the top of the logic board. A magnetized screw may interfere with the digital compass.
Quite los siguientes tornillos que sujetan la placa lógica a la caja trasera:
Estos tornillos tienen un patrón de bits Phillips, pero encontramos la mejor herramienta de extracción para ser un conductor de cabeza plana de 2,5 mm.
Los tornillos separadores se remueven mejor utilizando la punta de destornillador de tornillos separador del iPhone y un mango de destornillador.
Si no hay otra opción, un pequeño destornillador de cabeza plana funcionará—pero ten precaución extra para asegurarte de que no se resbale y dañe los componentes circundantes.
[* black] Remove the following screws securing the logic board to the rear case:
[* red] Two 2.3 mm Phillips screws
[* orange] Two 2.7 mm standoff screws
- [* icon_note] Standoff screws are best removed using an [product|IF145-343|new_window=true] and [product|IF145-326|driver handle|new_window=true].
+ [* icon_note] Standoff screws are best removed using a [product|IF145-388-4|standoff screwdriver|new_window=true] or bit.
[* icon_caution] In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
[* yellow] One non-magnetic 2.7 mm standoff screw
[* icon_note] Be sure to put this screw back in its original position at the top of the logic board. A magnetized screw may interfere with the digital compass.
