Saltar al contenido principal
Reemplazo de la cubierta de la base Dell Precision 5520
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Dell Precision 5520 Base Cover Replacement: paso 0, imagen 1 de 2 Dell Precision 5520 Base Cover Replacement: paso 0, imagen 2 de 2
  • Be sure to power off and unplug your device before you begin your repair.
  • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
  • Pry the edges of the base cover and lift it to remove it from the computer.
  • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
Dé la vuelta a la solapa de la placa del sistema (1) y luego retire los diez tornillos M2x3 que aseguran la cubierta de la base a la computadora (2).
Haga palanca en los bordes de la cubierta de la base y levántela para quitarla de la computadora.
NOTA: Use un destornillador Torx # 5 para los tornillos de la base y un destornillador Philips para los dos tornillos M2x8 dentro de la aleta de la placa.
+[* icon_note] Be sure to power off and unplug your device before you begin your repair.
[* black] Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
[* black] Pry the edges of the base cover and lift it to remove it from the computer.
- [* icon_note] NOTE: Use a Torx #5 screwdriver for the base screws and a Philips screwdriver for the two M2x8 screws inside the badge flap.
+ [* icon_note] NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
