Saltar al contenido principal
iMac Intel 20" EMC 2105 and 2118 Front Bezel Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 23 guías que incluyen este paso.
Inglés
Español
Paso 2
iMac Intel 20" EMC 2105 and 2118 Front Bezel Replacement: paso 0, imagen 1 de 3 iMac Intel 20" EMC 2105 and 2118 Front Bezel Replacement: paso 0, imagen 2 de 3 iMac Intel 20" EMC 2105 and 2118 Front Bezel Replacement: paso 0, imagen 3 de 3
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches. Or use two cards for the additional thickness.
  • If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
Insertar traducción aquí
