Saltar al contenido principal
Reemplazo de cristal trasero de Samsung Galaxy S7
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 2
Samsung Galaxy S7 Rear Glass Replacement: paso 0, imagen 1 de 3 Samsung Galaxy S7 Rear Glass Replacement: paso 0, imagen 2 de 3 Samsung Galaxy S7 Rear Glass Replacement: paso 0, imagen 3 de 3
  • When the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
  • The suction cup will not make a good seal on the curved portion of the glass.
  • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  • Lift on the suction cup and insert an opening pick under the rear glass.
  • The rear glass can break if you use too much force or attempt to pry with metal tools.
  • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
  • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
Una vez que el panel esté lo suficientemente caliente al tacto, coloca una ventosa lo más cerca posible del borde calentado, evitando la parte curvada.
La ventosa no aplica una buena sujeción en la parte curvada del cristal.
Si la tapa trasera del teléfono está rasgada, la ventosa no podrá adherirse. Intenta levantarla con una cinta resistente o pega con adhesivo instantáneo la ventosa y permite que se pega así puedes proceder.
Levanta de la ventosa e inserta un spudger Haldberd o púa de apertura debajo del cristal trasero.
El cristal trasero se puede romper si utilizas mucha fuerza o intentas de hacer palanca con herramientas de metal.
Debido a la curva del cristal, deberás tirar hacia arriba con la ventosa en vez de introducir la herramienta de forma paralela al plano del teléfono.
Si tienes problemas, aplica más calor para ablandar más el adhesivo e intenta nuevamente. El adhesivo se enfría muy rápido, así que quizá deberás calentarlo repetidamente.
Como opción, una vez que la púa esté introducida, puedes agregar unas pocas gotas de alcohol isopropílico dentro del espacio para ayudar a debilitar el adhesivo en los pasos siguientes.
