Saltar al contenido principal
HP Compaq Presario V5303NR Cooling Fan Replacement
Inglés
Español
Paso 6
HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 1 de 3 HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 2 de 3 HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 3 de 3
  • Carefully unplug the plastic piece at the end of the wire from the motherboard at the highlighted point.
  • Carefully remove said plastic piece from the end of the wire bundle at the end of the wire.
  • Do not lose this plastic piece, as it plugs the fan into the fan's power supply.
  • Be very careful to avoid damaging any of the components listed above. If any of these parts are damaged, the fan, if not the computer as a whole, could be irreparably damaged.
Insertar traducción aquí
