Saltar al contenido principal
HP Compaq Presario V5303NR Cooling Fan Replacement
Inglés
Holandés
Paso 4
HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 1 de 2 HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 2 de 2
  • Use the metal spudger to pry open the two metal latches affixing the fan cover to the laptop.
  • Use the Phillips #00 screwdriver to remove the 4mm #00 screw affixing the fan cover to the laptop.
  • A plastic spudger has a decreased risk of damaging the computer and its components, so it would normally be preferred over the metal. However, due to the limited amount of space between the latch and the fan's casing, the plastic one may not fit, as was the case in the photo above.
Insertar traducción aquí
