Saltar al contenido principal
HP Compaq Presario V5303NR Cooling Fan Replacement
Inglés
Holandés
Paso 2
HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 1 de 2 HP Compaq Presario V5303NR Cooling Fan Replacement: paso 0, imagen 2 de 2
  • Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
  • Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
  • Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
  • Keep the different types of screws separate from one another. They will only fit into holes created for screws of their size, and thus cannot fit into other screw holes.
Insertar traducción aquí
