Saltar al contenido principal
Cómo diagnosticar el JBL Flip 3
Inglés
Español
Traduciendo paso 3
Paso 3
How to diagnose JBL Flip 3, Actions: paso 0, imagen 1 de 3 How to diagnose JBL Flip 3, Actions: paso 0, imagen 2 de 3 How to diagnose JBL Flip 3, Actions: paso 0, imagen 3 de 3
Actions
  • USB: I suggest to replace the module instead of trying to replace the port. Its quite hard. Small pins delicate pads close plastic. Good luck.
  • Battery: Get a new one. Its not too hard to replace the battery. Just don't pull the connector. Use a flathead screwdriver to brace the plastic part the connector is connected to else it could come off the motherboard. You have to dig out glue to get the connector out but just go slow and avoid putting too much pressure on the cable.
  • Inductor: Solder on the component "1R5" its not hard if you use flux but don't hit the nearby pieces! I think I spent 30 seconds soldering this but 30 minutes getting to it!
  • Ribbon: Replace the ribbon. You have to remove the motherboard so most of the risk is getting to the ribbon. Sometimes the connectors have glue other times they don't. Spend the extra time thinking it through before you act!
  • Microcontroller: Kiss it goodbye. Im stockpiling these boards until I get a hot air station. If you can get that replaced with a soldering iron, your my hero! I do know there are people who can do it but I'd rather not wreck lots of them to know I need the right tool.
USB: sugiero reemplazar el módulo en lugar de intentar reemplazar el puerto. Es bastante difícil. Pequeños alfileres, almohadillas delicadas cierran el plástico. Buena suerte
Batería: Consigue una nueva. No es demasiado difícil reemplazar la batería. Simplemente no tires del conector. Usa un destornillador de punta plana para sujetar la parte plástica a la que está conectado el conector, de lo contrario, podría desprenderse de la placa base.
Tienes que sacar el pegamento para sacar el conector, pero hazlo lentamente y evita ejercer demasiada presión sobre el cable.
Inductor: Soldar el componente "1R5" no es difícil si usas fundente pero no golpeas las piezas cercanas. ¡Creo que pasé 30 segundos soldando esto, pero 30 minutos para lograrlo!
Cinta: reemplace la cinta. Tienes que quitar la placa base para que el mayor riesgo sea llegar a la cinta. A veces los conectores tienen pegamento otras veces no. ¡Dedique más tiempo a pensarlo detenidamente antes de actuar!
Microcontrolador: despídete de él. Estoy acumulando estas placas hasta que consiga una estación de aire caliente. Si puedes reemplazarla con un soldador, ¡eres mi héroe! Sé que hay gente que puede hacerlo, pero prefiero no destrozar muchas de ellas para saber que necesito la herramienta adecuada.
