Saltar al contenido principal
ionvac SmartClean V2 Side Brush Replacement
Qué necesitas
  1. ionvac SmartClean V2 Side Brush Replacement, Side Brush: paso 1, imagen 1 de 2 ionvac SmartClean V2 Side Brush Replacement, Side Brush: paso 1, imagen 2 de 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
    • Grasp the half-circle holding the brush into the bottom of your ionvac.
  2. ionvac SmartClean V2 Side Brush Replacement: paso 2, imagen 1 de 1
    • Gently pull on the brush head until it is released from the frame.
    • If the side brush is stuck, you can use a pry tool to pry it out.
    • Check out our Troubleshooting Page for cleaning instructions.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 142
