Saltar al contenido principal
iRobot Roomba 692 Motherboard Replacement
Qué necesitas
  1. iRobot Roomba 692 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Motherboard Replacement: paso 2, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement: paso 2, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Motherboard Replacement: paso 3, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement: paso 3, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement: paso 3, imagen 3 de 3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Remove the ten 13.3 mm screws with a Phillips #00 screwdriver.
    • Pull off the outer and inner holders.
  5. iRobot Roomba 692 Motherboard Replacement: paso 5, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement: paso 5, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 7.4 mm screws that secure the sensor.
    • Once screws are removed slide out the sensor to free it from the slide bumper.
  6. iRobot Roomba 692 Motherboard Replacement: paso 6, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement: paso 6, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement: paso 6, imagen 3 de 3
    • Wedge open the top with an opening tool.
    • Wedge the side tabs and middle tabs upward to remove the top lid.
  7. iRobot Roomba 692 Motherboard Replacement: paso 7, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement: paso 7, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement: paso 7, imagen 3 de 3
    • Use a Phillips #00 screwdriver to unscrew and remove the following screws:
    • Ten 9.6 mm screws.
    • Four 9.4 mm screws.
    • One 9.5 mm screw.
  8. iRobot Roomba 692 Motherboard Replacement: paso 8, imagen 1 de 3 iRobot Roomba 692 Motherboard Replacement: paso 8, imagen 2 de 3 iRobot Roomba 692 Motherboard Replacement: paso 8, imagen 3 de 3
    • Lift up the top cover to access the motherboard.
    • Use the Phillips #00 screwdriver to remove all five 7.6 mm screws that are holding it down.
  9. iRobot Roomba 692 Motherboard Replacement: paso 9, imagen 1 de 2 iRobot Roomba 692 Motherboard Replacement: paso 9, imagen 2 de 2
    • Unplug the wiring by pulling it outward.
    • Once all plugs are off the motherboard it can be removed, repaired, or replaced.
Conclusión
Ruth Oliva
Miembro Desde 11/08/23
217 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-1, Harley Fall 2023 Miembro de IUPUI, Team 1-1, Harley Fall 2023
IUPUI-HARLEY-F23S1G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 273
