Saltar al contenido principal
iPod Mini Bottom Bezel Replacement
Qué necesitas
  1. iPod Mini Bottom Bezel Replacement, Bottom Bezel: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    Jimmy
    $7.95
    Comprar
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
  2. iPod Mini Bottom Bezel Replacement: paso 2, imagen 1 de 1
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
  3. iPod Mini Bottom Bezel Replacement: paso 3, imagen 1 de 1
    • Lift the metal retaining bracket out of the iPod.
Conclusión
15 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
Un comentario
After removing my bottom bezel, I needed a couple small, cut pieces of double sided tape to hold it in place upon reassembly.
Stephen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 67
Todo El Tiempo: 19,137
