Saltar al contenido principal
iPhone 6s The screen Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
Resumen del Video
  1. iPhone 6s The screen  Replacement, The screen: paso 1, imagen 1 de 1
    • 1. Look at the phone and try to get the water out
  2. iPhone 6s The screen  Replacement: paso 2, imagen 1 de 1
    • 2. Next take it apart like the sim card and let that dry out for like 24 hours.
  3. iPhone 6s The screen  Replacement: paso 3, imagen 1 de 1
    • 3. If it doesn't help then try the rice method by putting the phone in the rice as well as the sim card.
  4. iPhone 6s The screen  Replacement: paso 4, imagen 1 de 1
    • 4. You can also use silica gel sachets to help with the drying.
  5. iPhone 6s The screen  Replacement: paso 5, imagen 1 de 1
    • 5.If that doesn't help your battery is probably damaged and you can replace it or just get a whole new phone.
  6. iPhone 6s The screen  Replacement: paso 6, imagen 1 de 1
    • Try to turn on the phone to see if it works if not then your screen is probably damaged if you don't see anything come on.
  7. iPhone 6s The screen  Replacement: paso 7, imagen 1 de 1
    • Start by unscrewing the screen to look and identify the whole problem.
  8. iPhone 6s The screen  Replacement: paso 8, imagen 1 de 1
    • After you look at whats wrong, start to replace the screen
  9. iPhone 6s The screen  Replacement: paso 9, imagen 1 de 1
    • If you can fix the screen and get it replaced but it wont hold a charge then the battery is probably damaged and you will have to try and get a new one.
  10. iPhone 6s The screen  Replacement: paso 10, imagen 1 de 1
    • Once you put a new battery put the screws back in may sure it's in correctly and try to power non your phone and it should work.
Conclusión
Now once it's all done put the phone back together and it should be back in full functioning mode
2 personas más completaron esta guía.
anonymous 591
Miembro Desde 04/25/18
235 Reputación
1 Guía escrita
Un comentario
What does everyone think is it helpful?
anonymous 591 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 934
