Saltar al contenido principal
iPhone 6s Display Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. iPhone 6s Display Replacement, Battery Connection: paso 1, imagen 1 de 1
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Display Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    iSclack
    $24.99
    Comprar
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Display Replacement: paso 3, imagen 1 de 3 iPhone 6s Display Replacement: paso 3, imagen 2 de 3 iPhone 6s Display Replacement: paso 3, imagen 3 de 3
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Display Replacement: paso 4, imagen 1 de 2 iPhone 6s Display Replacement: paso 4, imagen 2 de 2
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Display Replacement: paso 5, imagen 1 de 2 iPhone 6s Display Replacement: paso 5, imagen 2 de 2
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Display Replacement: paso 6, imagen 1 de 2 iPhone 6s Display Replacement: paso 6, imagen 2 de 2
  7. iPhone 6s Display Replacement: paso 7, imagen 1 de 3 iPhone 6s Display Replacement: paso 7, imagen 2 de 3 iPhone 6s Display Replacement: paso 7, imagen 3 de 3
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Display Replacement: paso 8, imagen 1 de 1
    • Lean the display against something to keep it propped up while you're working on the phone.
  9. iPhone 6s Display Replacement: paso 9, imagen 1 de 1
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Display Replacement: paso 10, imagen 1 de 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Display Replacement: paso 11, imagen 1 de 3 iPhone 6s Display Replacement: paso 11, imagen 2 de 3 iPhone 6s Display Replacement: paso 11, imagen 3 de 3
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
  12. iPhone 6s Display Replacement, Display: paso 12, imagen 1 de 1
    • While holding the front panel open at about a 90º angle, remove the following screws securing the front panel assembly cable bracket:
    • Three 1.3 mm Phillips #00 screws
    • Don't lose track of this screw! It's very important that the one 3.0 mm screw goes in the top-right corner of the plate. Anywhere else may cause damage to the logic board.
  13. iPhone 6s Display Replacement: paso 13, imagen 1 de 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6s Display Replacement: paso 14, imagen 1 de 3 iPhone 6s Display Replacement: paso 14, imagen 2 de 3 iPhone 6s Display Replacement: paso 14, imagen 3 de 3
    • In the next three steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use the flat end of a spudger to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6s Display Replacement: paso 15, imagen 1 de 3 iPhone 6s Display Replacement: paso 15, imagen 2 de 3 iPhone 6s Display Replacement: paso 15, imagen 3 de 3
    • Use the flat end of a spudger to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  16. iPhone 6s Display Replacement: paso 16, imagen 1 de 2 iPhone 6s Display Replacement: paso 16, imagen 2 de 2
    • Finally, use the flat end of a spudger to disconnect the digitizer cable connector.
  17. iPhone 6s Display Replacement: paso 17, imagen 1 de 2 iPhone 6s Display Replacement: paso 17, imagen 2 de 2
    • Remove the display assembly from the rear case.
Conclusión
153 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,780 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
21 comentarios
while technically correct, this guide is not complete in the sense that a new tech cannot follow it step-by-step to successfully complete a screen replacement. You should include the steps necessary to move the parts over from the old screen. Yes you can buy screen replacements with small parts but most repair operations don't do that as it isn't that hard to move them and much less expensive.
There are many small parts involved in moving from one screen to another. There are also a few steps that require prying a flex from the frame that is taped down. Having the additional steps in this guide that point out exactly where each small parts go and how to successfully pull the flex off without tearing it would be a huge improvement to this guide (and all the other screen replacement guides as they all have the same gap)
thanks - this is a great site and my techs use it for training every day.
Marty Morrow - Contestar
The demo ends before it does what is stated in the heading (Display Replacement.) This demo is for Front Panel Assembly Replacement.
PJL500 -
As stated in the intro, this is just the full front panel assembly guide. We'll be posting more thorough screen replacement guides in the future. Stay tuned ;)
Sam Goldheart -
When will you be selling the 6S replacement screen. I only see on for the 6 and it says not compatible with the 6S.
Additionally is it possible to replace just the glass and not all the other parts?
dougross - Contestar
That is what i am curious about as well!!!
just cracked the glass in the bottom left corner of my 6s Plus.
brink28 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 185,373
