Introducción
Use this guide to replace the power button assembly cable, including the mechanical power switch, camera flash, and microphone.
Qué necesitas
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
Peel back the first battery adhesive tab from the bottom right edge of the battery.
Gently pull the battery adhesive tab away from the battery, toward the bottom of the iPhone.
Try not to pull against the battery or the lower components, or you may rip the adhesive strip.
Continue pulling, allowing the strip to slowly slip out from between the battery and the rear case. When you feel increased resistance from the strip, stop pulling and continue with the next step.
When you feel increased resistance from the adhesive strip, pull it gently around the lower right corner of the battery.
Continue pulling the adhesive tab upward and away from the right edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
Peel back the second battery adhesive tab from the bottom left edge of the battery.
Again, gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
Continue pulling the adhesive tab until you feel increased resistance, and then stop.
When you feel increased resistance from the adhesive strip, pull it gently around the lower left corner of the battery.
Continue pulling the adhesive tab upward and away from the left edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
If you removed both adhesive strips successfully, skip the next two steps and continue on Step 46.
If either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Insert a plastic card under the logic board edge of the battery.
Press the card in at several points if necessary to break up the adhesive behind the battery.
Begin to peel the flash/microphone/power button assembly cable up from the rear case starting from the connector end.
Continue to peel the cable up, being particularly careful of the narrow component ends of the cable.
Remove the flash/microphone/power button assembly cable from the phone.
84 personas más completaron esta guía.
11 comentarios
This helped out a lot, couldn't find a good enough photo on how the power button was put back on its mount.
Took me 2.5 hours to complete this. Had a hard time getting the factory cable connector off the power button. Used some 3M Double Sided Adhesive tape- 2mm width, Black color to hold the new replacement cable connector in place on the power button. An IFIXIT video showing how to install the connector onto the power switch would be a big help. Had to use a You-Tube video to complete that step. Also, a good reminder to ensure all your connector cables are clear when reinstalling the logic board. You definitely don't want to pinch any of them. Follow the directions carefully and patience is a must! Wasn't that hard for my first time replacing this flex cable.
PRO TIP Order a part that already has the metal bracket attached for a few cents more and save yourself the hassle. I buy all my parts on eBay because of their awesome buyer protection and sellers always want to keep a good rating.
I think I got a broken cable. Can someone help me with that?
It looks like this: https://drive.google.com/drive/folders/1...
Is it broken and can I fix it? Or is this normal and what to do?
