Saltar al contenido principal
Este desmontaje no es una guía de reparación. Para reparar tu iPhone 16 Pro, utiliza nuestros manuales de servicio .
  1. iPhone 16 Pro Chip ID, Logic board overview: paso 1, imagen 1 de 1
  2. iPhone 16 Pro Chip ID, RF Board Top: paso 2, imagen 1 de 2 iPhone 16 Pro Chip ID, RF Board Top: paso 2, imagen 2 de 2
    • STMicroelectronics ST33J eSIM/secure element
    • Qualcomm PMX65-000 power management
    • Cirrus Logic 338S01087 audio amplifier
    • Qualcomm clock generator
    • Analog Devices MAX11390A analog to digital converter
  3. iPhone 16 Pro Chip ID, RF Board Top - Connectivity: paso 3, imagen 1 de 1
    • Qualcomm SDR735-001 RF transceiver
    • Qualcomm SMR546-002 IF transceiver
    • Broadcom AFEM-8234 front-end module
    • Skyworks SKY58440-11 front-end module
    • Qorvo QM76307 front-end module
  4. iPhone 16 Pro Chip ID, RF Board Bottom: paso 4, imagen 1 de 2 iPhone 16 Pro Chip ID, RF Board Bottom: paso 4, imagen 2 de 2
    • Texas Instruments LM3567A1 LED flash driver
    • Broadcom BCM59367A1 wireless charging controller
    • Qualcomm QET7100-001 wideband envelope tracker
    • Qorvo envelope tracker power supply
    • Apple 338S00616 DC-DC converter
  5. iPhone 16 Pro Chip ID, RF Board Bottom - Connectivity: paso 5, imagen 1 de 1
    • Qualcomm SDX71M-000 modem
    • Skyworks front-end module
    • Qorvo QM76306 front-end module
    • Possibly NXP Semiconductors NFC controller
  6. iPhone 16 Pro Chip ID, Main Board Top: paso 6, imagen 1 de 2 iPhone 16 Pro Chip ID, Main Board Top: paso 6, imagen 2 de 2
    • Micron MT62F1G64D4AQ-031 XT:C LPDDR5X SDRAM layered over an Apple APL1V07 / 339S01527 A18 Pro hexa-core applications processor w/ GPU & Neural Engine
    • Apple APL109A / 338S01119 power management
    • STMicroelectronics STPMIA3C power management
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
  7. iPhone 16 Pro Chip ID, Main Board Top - Connectivity: paso 7, imagen 1 de 1
    • USI 339M00326 UWB module
  8. iPhone 16 Pro Chip ID, Main Board Bottom: paso 8, imagen 1 de 2 iPhone 16 Pro Chip ID, Main Board Bottom: paso 8, imagen 2 de 2
    • Kioxia K5A3RF9864 128 GB NAND flash memory
    • Likely Texas Instruments SN2012027 USB type-C controller
    • Likely Texas Instruments CP3200B1G0 battery charger
    • Cirrus Logic 338S00967 audio codec
    • Texas Instruments TPS65657B0 display power supply
    • Likely Cirrus Logic 338S00843 power management
  9. iPhone 16 Pro Chip ID: paso 9, imagen 1 de 1
    • Likely Texas Instruments TPS61280H battery front-end DC-DC converter
    • Apple 338S01026-B1 power management
  10. iPhone 16 Pro Chip ID, Main Board Bottom - Connectivity: paso 10, imagen 1 de 1
    • Likely USI 339S01464 Bluetooth & WiFi Module
    • NXP Semiconductors NFC controller
  11. iPhone 16 Pro Chip ID, Main Board Bottom - Sensors: paso 11, imagen 1 de 1
    • Bosch Sensortec accelerometer & gyroscope
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 69
Ultimos 7 días: 443
Ultimos 30 días: 2,001
Todo El Tiempo: 15,027
