Saltar al contenido principal
iPad mini 4 Wi-Fi Home Button Assembly Replacement
Qué necesitas
  1. iPad mini 4 Wi-Fi Home Button Assembly Replacement, Opening Procedure: paso 1, imagen 1 de 1
  2. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 2, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 2, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 2, imagen 3 de 3
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  3. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 3, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 3, imagen 2 de 2
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  4. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 4, imagen 1 de 1
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  5. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 5, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 5, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 5, imagen 3 de 3
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  6. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 6, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 6, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 6, imagen 3 de 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  7. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 7, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 7, imagen 2 de 2
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  8. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 8, imagen 1 de 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  9. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 9, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 9, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 9, imagen 3 de 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  10. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 10, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 10, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 10, imagen 3 de 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  11. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 11, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 11, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 11, imagen 3 de 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  12. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 12, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 12, imagen 2 de 2
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  13. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 13, imagen 1 de 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  14. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 14, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 14, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 14, imagen 3 de 3
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  15. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 15, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 15, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 15, imagen 3 de 3
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  16. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 16, imagen 1 de 1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  17. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 17, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 17, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 17, imagen 3 de 3
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  18. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 18, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 18, imagen 2 de 2
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  19. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 19, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 19, imagen 2 de 2
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  20. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 20, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 20, imagen 2 de 2
    • Slide the pick around the lower left edge of the iPad.
  21. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 21, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 21, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 21, imagen 3 de 3
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  22. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 22, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 22, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 22, imagen 3 de 3
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  23. iPad mini 4 Wi-Fi Home Button Assembly Replacement, Battery Connector: paso 23, imagen 1 de 1
    • To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
  24. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 24, imagen 1 de 1
    • Remove the battery/display cable bracket.
  25. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 25, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 25, imagen 2 de 2
    • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
    • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
  26. iPad mini 4 Wi-Fi Home Button Assembly Replacement, Display Assembly: paso 26, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement, Display Assembly: paso 26, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement, Display Assembly: paso 26, imagen 3 de 3
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  27. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 27, imagen 1 de 1
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
  28. iPad mini 4 Wi-Fi Home Button Assembly Replacement, Home Button Assembly: paso 28, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement, Home Button Assembly: paso 28, imagen 2 de 2
    • Use the pointed tip of a spudger to flip up the retaining flap on the home button ZIF socket.
  29. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 29, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 29, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 29, imagen 3 de 3
    • Use tweezers to unplug the home button ribbon cable from the ZIF socket.
    • Continue peeling the ribbon cable up to the EMI shield.
  30. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 30, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 30, imagen 2 de 2
    • Use tweezers to lift the home button control hardware module off the display assembly.
  31. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 31, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 31, imagen 2 de 2
    • Use an opening pick to continue separating the home button ribbon cable from the display assembly.
    • If you use metal tools to separate this cable, you may scratch the iPad glass, removing some paint.
  32. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 32, imagen 1 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 32, imagen 2 de 3 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 32, imagen 3 de 3
    • Use a plastic opening tool to pry the home button bracket off the display assembly.
    • When replacing this bracket, it's recommended to use some high-bond tape to secure it.
  33. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 33, imagen 1 de 1
    • Heat an iOpener and lay it over the lower edge of the front panel to soften the adhesive holding the home button in place.
  34. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 34, imagen 1 de 2 iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 34, imagen 2 de 2
    • The home button is held in place by a thin, delicate, rubber gasket that is mildly adhered to the front panel.
    • Slowly push the home button up and out of the display assembly to separate the gasket from the front panel.
    • Be careful to not push the gasket past its tearing point. If the adhesive is adequately heated, it will separate from the front panel with some gentle pressure.
  35. iPad mini 4 Wi-Fi Home Button Assembly Replacement: paso 35, imagen 1 de 1
    • Remove the home button assembly.
Conclusión
27 personas más completaron esta guía.
Evan Noronha
Miembro Desde 02/05/15
223,535 Reputación
168 Guías creadas
5 comentarios
Is the piece of tape connecting the HB cable to the bracket important?
Perrin Aybara - Contestar
Home Button still does not work after home button transfer and digitizer replacement.
MC EnderFromVN - Contestar
there is a tiny black circle on the actual button underneath the kapton tape. if that isnt properly lined up it will not depress properly. also if the collar isnt perfect the home button will not sit correctly and popout. its a pretty crappy design by apple.
jsox79 -
I agree crappy design, i tried realigning button several times, best i got was “sort of works”
josh - Contestar
It took me several attempts - but I eventually got mine to work perfectly. I had put glue on the bracket - since there was glue on the old one - but that made the gap too wide, so it wasn’t seating the home button right. I also had a replacement that had a slightly bent plug for the touch - so it wasn’t seating properly and the touchscreen was not consistent. I eventually got it all seated (the connector and the home button). Then it worked like a charm. Thanks for the guide.
Jason Kolberg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 44
Ultimos 30 días: 184
Todo El Tiempo: 16,114
