Introducción
Use this guide to remove, replace or upgrade the RAM in your iMac Intel 27" Retina 5K Display.
Qué necesitas
While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
Re-insert the RAM access door back into its place.
114 personas más completaron esta guía.
22 comentarios
At the end: "To reassemble your device, follow these instructions in reverse and use our adhesive strip replacement guide to reattach the display glass."
This does not make sense for a memory replacement guide.
I made a few changes to the guide to make it more readable. Thanks for the tip!
I am thinking about getting me an iMac 5K but not really interested in overpaying for my RAM - can I access all 4 slots in the newest iMac 5K so I could buy the entry level with 8GB and then upgrade it to 32GB myself?
Yes, but make sure they are the same frequency so there won't be any issues. (1867)
vsomme -
