Saltar al contenido principal
iMac Intel 21.5" EMC 2428 Hard Drive Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. iMac Intel 21.5" EMC 2428 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Remove the two T8 Torx screws securing the upper bracket to the hard drive.
    • Remove the upper bracket from the hard drive.
  2. iMac Intel 21.5" EMC 2428 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove the two T8 Torx pins from the other side of the hard drive.
  3. iMac Intel 21.5" EMC 2428 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Carefully peel off the piece of EMI foam attached to the front of the hard drive.
    • Don't forget to transfer this to your new hard drive.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Yes, but how do I open the case to get to the drive? Where do the suction cups come in? What is the EMI foam for?
This guide is missing several steps.
unlvkatherine - Contestar
Hi! You have somehow stumbled upon a prerequisite guide that is improperly labeled. This guide is supposed to be used in part with a larger guide.
You can find the complete guide here. Sorry about the confusion!
Arthur Shi -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 6,195
