Saltar al contenido principal
iHome iBT16 Motherboard Replacement
Qué necesitas
  1. iHome iBT16 Motherboard Replacement, Base Plate: paso 1, imagen 1 de 2 iHome iBT16 Motherboard Replacement, Base Plate: paso 1, imagen 2 de 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: paso 2, imagen 1 de 2 iHome iBT16 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 iHome iBT16 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 iHome iBT16 Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: paso 4, imagen 1 de 2 iHome iBT16 Motherboard Replacement: paso 4, imagen 2 de 2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the plastic cover from the power switch actuator on the motherboard.
Conclusión
Joseph Hazel
Miembro Desde 03/24/17
353 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,155
