Saltar al contenido principal
iHome IH11 Speaker Replacement
Qué necesitas
  1. iHome IH11 Speaker Replacement, Outer Case: paso 1, imagen 1 de 1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Speaker Replacement: paso 2, imagen 1 de 2 iHome IH11 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the two 9.0mm screws on the back of the iHome with a Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the two 12.0mm screws holding the speaker to the iHome with a Phillips #1 screwdriver.
  4. iHome IH11 Speaker Replacement: paso 4, imagen 1 de 2 iHome IH11 Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the four 12.0mm screws on the face of the speaker with the Phillips #1 Screwdriver.
    • Carefully lift speaker out of its casing.
  5. iHome IH11 Speaker Replacement: paso 5, imagen 1 de 1
    • Unsolder the two wires that connect to the speaker.
Conclusión
Equipo
Cal Poly, Team 14-9, Maness Spring 2013 Miembro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 332
