Saltar al contenido principal
iHome IH11 Main Motherboard Replacement
Qué necesitas
  1. iHome IH11 Main Motherboard Replacement, Outer Case: paso 1, imagen 1 de 1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: paso 2, imagen 1 de 2 iHome IH11 Main Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: paso 4, imagen 1 de 2 iHome IH11 Main Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: paso 5, imagen 1 de 1
    • Solder each wire to corresponding input on the motherboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 14-9, Maness Spring 2013 Miembro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 394
