Saltar al contenido principal
iHome IH11 Dock Connector Replacement
Qué necesitas
  1. iHome IH11 Dock Connector Replacement, Dock Connector: paso 1, imagen 1 de 1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: paso 2, imagen 1 de 2 iHome IH11 Dock Connector Replacement: paso 2, imagen 2 de 2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: paso 3, imagen 1 de 1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
Conclusión
3 personas más completaron esta guía.
Nick Knowles
Miembro Desde 04/19/13
21 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-9, Maness Spring 2013 Miembro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Miembros
5 Guías creadas
2 comentarios
Where can I buy a replacement dock connector?
A Ross - Contestar
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,393
