Saltar al contenido principal
iHome IH11 Control Buttons Replacement
Qué necesitas
  1. iHome IH11 Control Buttons Replacement, Outer Case: paso 1, imagen 1 de 1
    • Unscrew the two 9.0 mm screws with the Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Control Buttons Replacement: paso 2, imagen 1 de 2 iHome IH11 Control Buttons Replacement: paso 2, imagen 2 de 2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two screws on the bottom.
  3. iHome IH11 Control Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the two 9mm screws from the top of the iHome with a Phillips #1 Screwdriver.
  4. iHome IH11 Control Buttons Replacement: paso 4, imagen 1 de 1
    • Pop the dock connector out of the iHome and gently pull the white plastic plug from the dock connector.
  5. iHome IH11 Control Buttons Replacement: paso 5, imagen 1 de 1
    • Carefully pull apart the device.
    • Remove the four screws that hold the circuit board for the buttons.
  6. iHome IH11 Control Buttons Replacement: paso 6, imagen 1 de 1
    • Desolder the four connections for the broken button.
    • Solder the new button in the place of the old one.
    • For more information about soldering, refer to the soldering device page. Soldering Skills
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 14-9, Maness Spring 2013 Miembro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 353
