Saltar al contenido principal
iHome IH11 AC Power Adapter Replacement
Qué necesitas
  1. iHome IH11 AC Power Adapter Replacement, Outer Case: paso 1, imagen 1 de 1
    • Unscrew the two 9.0 mm screws with the Phillips #1.
    • Remove the translucent bottom plastic piece.
  2. iHome IH11 AC Power Adapter Replacement: paso 2, imagen 1 de 2 iHome IH11 AC Power Adapter Replacement: paso 2, imagen 2 de 2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires attached to the back cover.
  3. iHome IH11 AC Power Adapter Replacement: paso 3, imagen 1 de 1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
  4. iHome IH11 AC Power Adapter Replacement, Motherboard: paso 4, imagen 1 de 2 iHome IH11 AC Power Adapter Replacement, Motherboard: paso 4, imagen 2 de 2
    • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 AC Power Adapter Replacement: paso 5, imagen 1 de 1
    • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
    • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
  6. iHome IH11 AC Power Adapter Replacement: paso 6, imagen 1 de 2 iHome IH11 AC Power Adapter Replacement: paso 6, imagen 2 de 2
    • Unsolder the main connections holding the AC adapter to the circuit board.
    • Solder new adapter in same position with same connections.
Conclusión
2 personas más completaron esta guía.
Nick Knowles
Miembro Desde 04/19/13
21 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-9, Maness Spring 2013 Miembro de Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 771
