Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement
Qué necesitas
  1. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    Pregunta a FixBot
    Agregar Comentario
  2. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 2, imagen 1 de 1
    • Lift the battery out of the computer.
    Pregunta a FixBot
    Agregar Comentario
  3. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Keyboard: paso 3, imagen 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again. The locking screw is in between the F5 and F6 keys and is a clear piece of plastic.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Pregunta a FixBot
    Agregar Comentario
  4. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 4, imagen 1 de 1
    • If the computer has an AirPort card installed, follow the next three steps to remove it.
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
    Pregunta a FixBot
    Agregar Comentario
  5. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 5, imagen 1 de 1
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
    Pregunta a FixBot
    Agregar Comentario
  6. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 6, imagen 1 de 1
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
    Pregunta a FixBot
    Agregar Comentario
  7. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 7, imagen 1 de 1
    • Remove the four silver Phillips screws that secure the RAM shield.
    Pregunta a FixBot
    Agregar Comentario
  8. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 8, imagen 1 de 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Pregunta a FixBot
    Agregar Comentario
  9. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 9, imagen 1 de 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
    Pregunta a FixBot
    Agregar Comentario
  10. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Lower Case: paso 10, imagen 1 de 1
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    Pregunta a FixBot
    Agregar Comentario
  11. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 11, imagen 1 de 1
    • Remove the three newly-revealed Phillips screws.
    Pregunta a FixBot
    Agregar Comentario
  12. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 12, imagen 1 de 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    Pregunta a FixBot
    Agregar Comentario
  13. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 13, imagen 1 de 1
    • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
    • The shorter screw is in the center of the computer.
    Pregunta a FixBot
    Agregar Comentario
  14. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 14, imagen 1 de 1
    • Remove the two Phillips screws on either side of the battery contacts.
    Pregunta a FixBot
    Agregar Comentario
  15. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 15, imagen 1 de 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    Pregunta a FixBot
    Agregar Comentario
  16. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 16, imagen 1 de 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • Be careful not to break this clip!
    Pregunta a FixBot
    Agregar Comentario
  17. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 17, imagen 1 de 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    Pregunta a FixBot
    Agregar Comentario
  18. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 18, imagen 1 de 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
    Pregunta a FixBot
    Agregar Comentario
  19. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 19, imagen 1 de 1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
    Pregunta a FixBot
    Agregar Comentario
  20. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 20, imagen 1 de 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    Pregunta a FixBot
    Agregar Comentario
  21. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 21, imagen 1 de 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    Pregunta a FixBot
    Agregar Comentario
  22. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Bottom Shield: paso 22, imagen 1 de 1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
    Pregunta a FixBot
    Agregar Comentario
  23. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 23, imagen 1 de 1
    • Lift the bottom shield off.
    Pregunta a FixBot
    Agregar Comentario
  24. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, DC-In Board: paso 24, imagen 1 de 1
    • Remove the single Phillips screw securing the DC-In board.
    Pregunta a FixBot
    Agregar Comentario
  25. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 25, imagen 1 de 1
    • Disconnect the DC-In cable from the logic board.
    Pregunta a FixBot
    Agregar Comentario
  26. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 26, imagen 1 de 1
    • Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
    Pregunta a FixBot
    Agregar Comentario
  27. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Upper Case: paso 27, imagen 1 de 1
    • Remove the following 11 screws from the bottom of the computer:
    • Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
    • Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
    • One 11 mm Phillips in the lower right corner. (if present)
    • Four 14.5 mm Phillips.
    Pregunta a FixBot
    Agregar Comentario
  28. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 28, imagen 1 de 1
    • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
    • Turn over the computer and open it.
    • Remove the 2 Phillips screws (3mm) from the edges of the keyboard area.
    • Remove the 4 mm Phillips screw from the lower left corner.
    Pregunta a FixBot
    Agregar Comentario
  29. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 29, imagen 1 de 1
    • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
    • Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
    Pregunta a FixBot
    Agregar Comentario
  30. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 30, imagen 1 de 1
    • Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
    Pregunta a FixBot
    Agregar Comentario
  31. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 31, imagen 1 de 1
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
    Pregunta a FixBot
    Agregar Comentario
  32. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 32, imagen 1 de 1
    • Carefully disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
    Pregunta a FixBot
    Agregar Comentario
  33. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Top Shield: paso 33, imagen 1 de 1
    • The screw circled in orange may not be present in some models.
    • Remove the following 16 screws:
    • Thirteen 3 mm Phillips.
    • One 3 mm Phillips. (actual screw not present in image)
    • Two 4 mm Phillips.
    • Be sure to fit the screw near the left hinge through the loop in the display data cable, securing the cable to the upper case.
    • Missing in this photo is the Bluetooth antenna present in some iBooks. It is located at the upper right corner of the battery compartment, just above the 4mm screw. You can see the bracket for the antenna in the photo. It is the two I-shaped holes just above the 4mm screw that must be removed in this step. To remove the antenna, slide it toward the LCD, and tilt it vertically back towards yourself.
    Pregunta a FixBot
    Agregar Comentario
  34. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 34, imagen 1 de 1
    • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
    • If your iBook has Bluetooth, as discussed in the previous step, you will need to slide the antenna through the lower I-shaped hole in the shield before completely removing the shield.
    Pregunta a FixBot
    Agregar Comentario
  35. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement, Optical Drive: paso 35, imagen 1 de 1
    • Remove the following 3 screws:
    • One 3 mm Phillips in the channel between the optical drive and fan.
    • One 6 mm Phillips from the upper end of the drive bezel.
    • One 6 mm Phillips with a collar from bracket extending from the lower left corner of the drive.
    Pregunta a FixBot
    Agregar Comentario
  36. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 36, imagen 1 de 1
    • There are two different styles of optical drive ribbon. If the cable extending from the optical drive is white, skip this step. If the cable is orange, then complete this step and skip the next two steps.
    • Disconnect the orange optical drive ribbon from the logic board.
    Pregunta a FixBot
    Agregar Comentario
  37. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 37, imagen 1 de 1
    • This is a diagram of the ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Pregunta a FixBot
    Agregar Comentario
  38. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 38, imagen 1 de 1
    • Release the optical drive ribbon clamp as described above. Slide the optical drive ribbon out of its connector.
    Pregunta a FixBot
    Agregar Comentario
  39. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 39, imagen 1 de 1
    • Lift the optical drive from the metal framework.
    Pregunta a FixBot
    Agregar Comentario
  40. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 40, imagen 1 de 1
    • Remove the two Phillips screws securing the metal bracket and cable to the back of the optical drive.
    Pregunta a FixBot
    Agregar Comentario
  41. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 41, imagen 1 de 1
    • Peel the cable up from the top of the optical drive, removing tape as necessary, and disconnect it.
    Pregunta a FixBot
    Agregar Comentario
  42. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 42, imagen 1 de 1
    • Remove the single Phillips screw securing the bezel at the front of the optical drive.
    • This screw is longer than the two that secure the bracket and cable at the back of the drive.
    Pregunta a FixBot
    Agregar Comentario
  43. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 43, imagen 1 de 1
    • The bezel has several small, fragile tabs that will break easily.
    • Use a spudger to carefully depress the two tabs on top of the bezel.
    Pregunta a FixBot
    Agregar Comentario
  44. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 44, imagen 1 de 1
    • Hold the optical drive on its side and depress the remaining tab to free the bezel from the drive.
    Pregunta a FixBot
    Agregar Comentario
  45. iBook G4 14" 933 MHz-1.33 GHz Optical Drive Replacement: paso 45, imagen 1 de 1
    • Turn the drive over and remove the two Phillips screws from the bracket on the side of the drive.
    • These screws are only partially threaded.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
24 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 65
Todo El Tiempo: 33,708
