Introducción
The heat sink helps keep the processor cool and happy.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Remove the following 15 screws:
Fourteen 3 mm Phillips.
One 5.5 mm Phillips in the upper left corner.
Remove the following 5 screws and 3 nuts from the heat sink:
One 3.5 mm Phillips from the lower left corner of the heat sink.
Three 6 mm Phillips from around the fan.
One 7.5 mm Phillips at the top right corner of the heat sink.
One 4 mm nut from the side of the heat sink.
Two 4 mm screw nuts with attached springs from either side of the heat sink.
5 personas más completaron esta guía.
