Introducción
The motherboard includes all ports except the DC-In board.
Herramientas
Partes
- iBook G3 14" 800 MHz Logic Board
- iBook G3 14" 600 MHz Heat Sink
- iBook G3 14" 600 MHz Metal Framework
- iBook G3 14" Hinge Grill
- iBook G3 14" Sleep Light
- iBook G3 14" Battery Connector
- iBook G3 14" 900 MHz Logic Board
- iBook G3 14" 900 MHz Hinge Grill
- iBook G3 14" Metal Framework (700 )
- iBook G3 14" 700 800 900 MHz Heat Sink
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the following 9 screws on the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 5 mm Phillips on the left and bottom edges.
Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
Remove the single Phillips screw on the left side of the fan.
Lift the fan out of its housing and disconnect it from the logic board.
Remove the following 16 screws:
Five 3 mm Phillips (these have smaller heads than the others).
Three 5 mm Phillips.
Eight 6 mm Phillips.
Remove the single strip of tape running across the modem.
Remove the single Phillips screw securing the display data cable to the metal framework.
Remove the single Phillips screw to the right of the hard drive connector.
Disconnect the microphone cable from the front, left corner of the logic board.
Peel back the black tape and free the microphone cable from the hard drive.
Remove the following 9 screws:
Two 3 mm Phillips from the edge of the logic board, near the battery
Two 4 mm large head Phillips on the port side, from either corner.
One 6 mm Phillips near the sleep light.
Two 7.5 mm Phillips securing the battery connector to the metal framework.
Two 5 mm Phillips from the logic board. These screws may not be present on some models.
7 personas más completaron esta guía.
Documentos Adjuntos
Un Comentario
You do need to follow basically this whole procedure for a thermal paste replacement.
