Saltar al contenido principal
Zoom H1 Handy Recorder Battery Terminal Replacement
Qué necesitas
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: paso 1, imagen 1 de 1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 3, imagen 1 de 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 4, imagen 1 de 1
    • Carefully pry up the top end of the back cover using one finger
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 5, imagen 1 de 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 6, imagen 1 de 1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 7, imagen 1 de 1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 8, imagen 1 de 2 Zoom H1 Handy Recorder Battery Terminal Replacement: paso 8, imagen 2 de 2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 9, imagen 1 de 1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: paso 10, imagen 1 de 1
    • Place second lead at point 2 and re-solder.
Conclusión
To Re-construct device, perform these steps in reverse order.
Alex
Miembro Desde 10/28/13
809 Reputación
5 Guías creadas
7 comentarios
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Contestar
Mine has third screw under the serial-number sticker.
halluciana - Contestar
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Contestar
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Contestar
Same problem, without any reason it is dead
eevilcute -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 41
Todo El Tiempo: 6,468
