Introducción
Use this guide to replace the screen on the Zeki Droid TBDC1093B.
Follow these instructions to disassemble the Zeki Droid and gain access to the broken screen. To prevent injury, I recommend following this guide to reinforce the broken glass.
Qué necesitas
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
