Saltar al contenido principal
Zeki Droid Tablet Front Screen Replacement
Qué necesitas
  1. Zeki Droid Tablet Front Screen Replacement, Back Casing: paso 1, imagen 1 de 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Front Screen Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Front Screen Replacement: paso 3, imagen 1 de 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Front Screen Replacement: paso 4, imagen 1 de 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Front Screen Replacement: paso 5, imagen 1 de 1
    • Pull the speakers away from the back casing carefullly.
  6. Zeki Droid Tablet Front Screen Replacement, Front Screen: paso 6, imagen 1 de 1
    • Detach the motherboard from the framing by removing the four screws using a Phillips #000 screwdriver.
  7. Zeki Droid Tablet Front Screen Replacement: paso 7, imagen 1 de 1
    Comprar
    • Lift the camera and flash components from their fittings using tweezers.
  8. Zeki Droid Tablet Front Screen Replacement: paso 8, imagen 1 de 1
    • Lift the metal framing to reach the components at the front of the device.
    • Do not pull the framing completely off. There is a ZIF connecter holding it in place.
  9. Zeki Droid Tablet Front Screen Replacement: paso 9, imagen 1 de 2 Zeki Droid Tablet Front Screen Replacement: paso 9, imagen 2 de 2
    • Push the screen forward to remove.
Conclusión
Kyla
Miembro Desde 03/11/15
156 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 321
