Saltar al contenido principal
Zeepad 7.0 Battery Replacement
Qué necesitas
  1. Zeepad 7.0 Battery Replacement, Battery: paso 1, imagen 1 de 2 Zeepad 7.0 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Battery Replacement: paso 2, imagen 1 de 2 Zeepad 7.0 Battery Replacement: paso 2, imagen 2 de 2
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each. Try to cut in the center of the two wires to solder after you replace it.
    • Try to separate the wires away from the other wires on the motherboard. This way you will not cut any additional wiring.
  3. Zeepad 7.0 Battery Replacement: paso 3, imagen 1 de 2 Zeepad 7.0 Battery Replacement: paso 3, imagen 2 de 2
    • Peel off the battery from the metal casing for the LED screen. The battery will be held down with an adhesive, and it will not take much pressure to be released.
    • There will be additional wiring hooked up to the motherboard. Make sure not to tangle up or damage any wiring close by.
    • Do not place much pressure onto the LED screen while peeling off the battery.
  4. Zeepad 7.0 Battery Replacement: paso 4, imagen 1 de 1
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wire to the new battery wire.
    • Once the solder melts and forms a bridge between the two wires, try to turn on the device then check for power.
    • Cómo soldar y desoldar conexiones
    • Keep the soldering iron away from the battery, motherboard, and any other wires. Do not let children around the soldering station.
Conclusión
To reassemble your device, follow the initial instructions in reverse order.
Jacob
Miembro Desde 03/26/18
139 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G1, Harley Spring 2018 Miembro de IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 Miembros
4 Guías creadas
Un comentario
Where can I get a replacement battery for my jelly bean zeepad 7.0/4.2 pocket edge?
veronica fisher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 435
