Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 2
Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each. Try to cut in the center of the two wires to solder after you replace it. Try to separate the wires away from the other wires on the motherboard. This way you will not cut any additional wiring.
  • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each. Try to cut in the center of the two wires to solder after you replace it.
  • Try to separate the wires away from the other wires on the motherboard. This way you will not cut any additional wiring.
Insertar traducción aquí
