Saltar al contenido principal
ZTE Prestige 2 Power and Volume Buttons Replacement
Qué necesitas
  1. ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: paso 1, imagen 1 de 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: paso 1, imagen 2 de 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: paso 1, imagen 3 de 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Power and Volume Buttons Replacement: paso 2, imagen 1 de 2 ZTE Prestige 2 Power and Volume Buttons Replacement: paso 2, imagen 2 de 2
    • Remove the battery.
  3. ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: paso 3, imagen 1 de 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: paso 3, imagen 2 de 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: paso 3, imagen 3 de 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Power and Volume Buttons Replacement: paso 4, imagen 1 de 3 ZTE Prestige 2 Power and Volume Buttons Replacement: paso 4, imagen 2 de 3 ZTE Prestige 2 Power and Volume Buttons Replacement: paso 4, imagen 3 de 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: paso 5, imagen 1 de 2 ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the curved tweezers to pull upwards and out on the the thin plastic attached on both sides of the power button and volume buttons. This process should allow the buttons to pop right out.
Conclusión
Mackenzie Peterson
Miembro Desde 02/04/20
169 Reputación
2 Guías creadas
Equipo
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 97
