Saltar al contenido principal
ZTE Prestige 2 Motherboard Replacement
Qué necesitas
  1. ZTE Prestige 2 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 ZTE Prestige 2 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 ZTE Prestige 2 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Motherboard Replacement: paso 2, imagen 1 de 2 ZTE Prestige 2 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the battery.
  3. ZTE Prestige 2 Motherboard Replacement, Back Panel: paso 3, imagen 1 de 3 ZTE Prestige 2 Motherboard Replacement, Back Panel: paso 3, imagen 2 de 3 ZTE Prestige 2 Motherboard Replacement, Back Panel: paso 3, imagen 3 de 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Motherboard Replacement: paso 4, imagen 1 de 3 ZTE Prestige 2 Motherboard Replacement: paso 4, imagen 2 de 3 ZTE Prestige 2 Motherboard Replacement: paso 4, imagen 3 de 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the three 3 mm Phillips #00 screws on the edges of the motherboard.
  6. ZTE Prestige 2 Motherboard Replacement: paso 6, imagen 1 de 3 ZTE Prestige 2 Motherboard Replacement: paso 6, imagen 2 de 3 ZTE Prestige 2 Motherboard Replacement: paso 6, imagen 3 de 3
    • Use the iFixit opening tool to dig under the sticker where the volume and the power buttons are located on both sides.
  7. ZTE Prestige 2 Motherboard Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the curved tweezers to gently remove the black cable running down the left side of the device and disconnect it from its socket.
  8. ZTE Prestige 2 Motherboard Replacement: paso 8, imagen 1 de 3 ZTE Prestige 2 Motherboard Replacement: paso 8, imagen 2 de 3 ZTE Prestige 2 Motherboard Replacement: paso 8, imagen 3 de 3
    • Use the curved tweezers to then unlock each of the ZIF connectors and pull the cables out.
    • The motherboard should now be able to fully disconnect from the rest of the device.
Conclusión
Una persona más ha completado esta guía.
Maria Stock
Miembro Desde 01/31/20
524 Reputación
5 Guías creadas
Equipo
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 203
