Saltar al contenido principal
ZTE Prestige 2 Back Camera Replacement
Qué necesitas
  1. ZTE Prestige 2 Back Camera Replacement, Battery: paso 1, imagen 1 de 3 ZTE Prestige 2 Back Camera Replacement, Battery: paso 1, imagen 2 de 3 ZTE Prestige 2 Back Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Back Camera Replacement: paso 2, imagen 1 de 2 ZTE Prestige 2 Back Camera Replacement: paso 2, imagen 2 de 2
    • Remove the battery.
  3. ZTE Prestige 2 Back Camera Replacement, Back Panel: paso 3, imagen 1 de 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: paso 3, imagen 2 de 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: paso 3, imagen 3 de 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Back Camera Replacement: paso 4, imagen 1 de 3 ZTE Prestige 2 Back Camera Replacement: paso 4, imagen 2 de 3 ZTE Prestige 2 Back Camera Replacement: paso 4, imagen 3 de 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Back Camera Replacement, Back Camera: paso 5, imagen 1 de 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: paso 5, imagen 2 de 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: paso 5, imagen 3 de 3
    • Use the iFixit opening pick and wedge it under the press fit connector beside the camera located at the top center of the device to pop it off.
    • Remove the camera.
    • The camera cable near the press fit connector is delicate, ripping it will cause permanent damage.
    • The base of the camera may be glued down which may lead to accidental ripping during removal. Use the flat end of a metal spudger to pry it up if necessary.
Conclusión
Maria Stock
Miembro Desde 01/31/20
524 Reputación
5 Guías creadas
Equipo
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 159
