Saltar al contenido principal
ZTE Maven 2 Motherboard Replacement
Qué necesitas
  1. ZTE Maven 2 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 3 ZTE Maven 2 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 3 ZTE Maven 2 Motherboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Motherboard Replacement, Battery: paso 2, imagen 1 de 1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Motherboard Replacement, MicroSD Card: paso 3, imagen 1 de 2 ZTE Maven 2 Motherboard Replacement, MicroSD Card: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Motherboard Replacement, Midframe: paso 4, imagen 1 de 1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Motherboard Replacement: paso 5, imagen 1 de 3 ZTE Maven 2 Motherboard Replacement: paso 5, imagen 2 de 3 ZTE Maven 2 Motherboard Replacement: paso 5, imagen 3 de 3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 ZTE Maven 2 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 ZTE Maven 2 Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    Comprar
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Motherboard Replacement: paso 7, imagen 1 de 2 ZTE Maven 2 Motherboard Replacement: paso 7, imagen 2 de 2
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Motherboard Replacement: paso 8, imagen 1 de 2 ZTE Maven 2 Motherboard Replacement: paso 8, imagen 2 de 2
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
82,698 Reputación
202 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,426 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 55
