Saltar al contenido principal
Yuneec ST16S Carrying Handle Replacement
Qué necesitas
  1. Yuneec ST16S Carrying Handle Replacement, Battery: paso 1, imagen 1 de 1
    • Hold down the button located above the battery while applying downward pressure to the battery.
  2. Yuneec ST16S Carrying Handle Replacement: paso 2, imagen 1 de 2 Yuneec ST16S Carrying Handle Replacement: paso 2, imagen 2 de 2
    • While still holding down the button, slide the battery out of its slot.
  3. Yuneec ST16S Carrying Handle Replacement, Backplate: paso 3, imagen 1 de 1
    • Remove the single screw from the battery compartment.
  4. Yuneec ST16S Carrying Handle Replacement: paso 4, imagen 1 de 2 Yuneec ST16S Carrying Handle Replacement: paso 4, imagen 2 de 2
    • Remove the rubber bumpers from the back of the device using a spudger.
  5. Yuneec ST16S Carrying Handle Replacement: paso 5, imagen 1 de 2 Yuneec ST16S Carrying Handle Replacement: paso 5, imagen 2 de 2
    • Remove the two screws located under each of the rubber bumpers.
  6. Yuneec ST16S Carrying Handle Replacement: paso 6, imagen 1 de 3 Yuneec ST16S Carrying Handle Replacement: paso 6, imagen 2 de 3 Yuneec ST16S Carrying Handle Replacement: paso 6, imagen 3 de 3
    • Remove the three screws along the top of the device.
  7. Yuneec ST16S Carrying Handle Replacement: paso 7, imagen 1 de 2 Yuneec ST16S Carrying Handle Replacement: paso 7, imagen 2 de 2
    • Carefully remove the backplate from the device.
  8. Yuneec ST16S Carrying Handle Replacement, Carrying Handle: paso 8, imagen 1 de 2 Yuneec ST16S Carrying Handle Replacement, Carrying Handle: paso 8, imagen 2 de 2
    • Remove the screws from the clips on both ends of the handle.
  9. Yuneec ST16S Carrying Handle Replacement: paso 9, imagen 1 de 2 Yuneec ST16S Carrying Handle Replacement: paso 9, imagen 2 de 2
    • Slide the clips away from the handle.
  10. Yuneec ST16S Carrying Handle Replacement: paso 10, imagen 1 de 1
    • Remove the handle from the device.
Conclusión
Equipo
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 Miembro de UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 60
