Introducción
To complete this guide you'll need a Philips #0 screwdriver and a spudger.
Qué necesitas
Flip the tablet with the rear panel facing up.
Push the central button to lift the support.
Open the support entirely, using your hands.
Remove the sticker using the plastic spudger by lifting it up from one side, then you can remove it entirely by using your fingers.
Use the Philips #0 screwriver to remove the three screws.
Divide the two halfs by inserting the spudger in the gap between the front shell and the rear one. To help you out with this job you can also use some guitar picks.
Do the same procedure on all three visible sides, including the two round side parts.
Once you unhook all the internal clips you can easily remove the rear panel.
To reassemble the device, folllow these instruction in reverse order.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Domenyck Paoly nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
