Introducción
Use this guide to remove or replace a broken rear camera glass in your Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Use the flat end of a spudger to pry up and disconnect the sensor cable of the rear camera glass.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
5 personas más completaron esta guía.
Un comentario
Hi, I need the part number of the cover with the sensors. The sensors are not working in my device.
