Saltar al contenido principal
Xbox One S All Digital Edition Power Supply Replacement
Qué necesitas
  1. Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: paso 1, imagen 1 de 3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: paso 1, imagen 2 de 3 Xbox One S All Digital Edition Power Supply Replacement, Plastic Enclosure: paso 1, imagen 3 de 3
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
  2. Xbox One S All Digital Edition Power Supply Replacement: paso 2, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement: paso 2, imagen 2 de 2
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
  3. Xbox One S All Digital Edition Power Supply Replacement: paso 3, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement: paso 3, imagen 2 de 2
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
  4. Xbox One S All Digital Edition Power Supply Replacement: paso 4, imagen 1 de 1
    • Flip the metal enclosure so that the fan cover is on top.
  5. Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: paso 5, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement, Top Metal Shield: paso 5, imagen 2 de 2
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
  6. Xbox One S All Digital Edition Power Supply Replacement: paso 6, imagen 1 de 3 Xbox One S All Digital Edition Power Supply Replacement: paso 6, imagen 2 de 3 Xbox One S All Digital Edition Power Supply Replacement: paso 6, imagen 3 de 3
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
  7. Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: paso 7, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement, Wifi Card: paso 7, imagen 2 de 2
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
  8. Xbox One S All Digital Edition Power Supply Replacement: paso 8, imagen 1 de 1
    • Carefully remove the WiFi Card from the metal chassis.
  9. Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: paso 9, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement, IR Blaster: paso 9, imagen 2 de 2
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
  10. Xbox One S All Digital Edition Power Supply Replacement: paso 10, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement: paso 10, imagen 2 de 2
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
  11. Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: paso 11, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement, Bottom Metal Shield: paso 11, imagen 2 de 2
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
  12. Xbox One S All Digital Edition Power Supply Replacement: paso 12, imagen 1 de 3 Xbox One S All Digital Edition Power Supply Replacement: paso 12, imagen 2 de 3 Xbox One S All Digital Edition Power Supply Replacement: paso 12, imagen 3 de 3
    • Remove the two plastic pieces from the motherboard.
  13. Xbox One S All Digital Edition Power Supply Replacement: paso 13, imagen 1 de 3 Xbox One S All Digital Edition Power Supply Replacement: paso 13, imagen 2 de 3 Xbox One S All Digital Edition Power Supply Replacement: paso 13, imagen 3 de 3
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
  14. Xbox One S All Digital Edition Power Supply Replacement, Power Supply: paso 14, imagen 1 de 3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: paso 14, imagen 2 de 3 Xbox One S All Digital Edition Power Supply Replacement, Power Supply: paso 14, imagen 3 de 3
    • Gently lift the hard drive to free up some space around the power supply.
  15. Xbox One S All Digital Edition Power Supply Replacement: paso 15, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement: paso 15, imagen 2 de 2
    • Lift the power supply up and away from the motherboard.
  16. Xbox One S All Digital Edition Power Supply Replacement: paso 16, imagen 1 de 2 Xbox One S All Digital Edition Power Supply Replacement: paso 16, imagen 2 de 2
    • Disconnect the six pin connector from the motherboard.
Conclusión
4 personas más completaron esta guía.
Jules Hajjar
Miembro Desde 10/10/19
1,531 Reputación
8 Guías creadas
Equipo
Cal Poly, Team S12-G6, Regan Fall 2019 Miembro de Cal Poly, Team S12-G6, Regan Fall 2019
CPSU-REGAN-F19S12G6
4 Miembros
26 Guías creadas
3 comentarios
I replaced the power supply and my Xbox still isn't turning on. I used a power supply I got from this website. Please help
William Oliver - Contestar
Another issue could be the power button on the front power board. If possible, you could try to replace that as well.
Jules Hajjar -
replace the PSU and still boots up and shuts off
imafuxer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 126
Todo El Tiempo: 6,862
