Saltar al contenido principal
WowWee MiP Robot LED Light Replacement
Qué necesitas
  1. WowWee MiP Robot LED Light Replacement, Battery: paso 1, imagen 1 de 2 WowWee MiP Robot LED Light Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot LED Light Replacement: paso 2, imagen 1 de 2 WowWee MiP Robot LED Light Replacement: paso 2, imagen 2 de 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot LED Light Replacement, Wheel: paso 3, imagen 1 de 2 WowWee MiP Robot LED Light Replacement, Wheel: paso 3, imagen 2 de 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot LED Light Replacement: paso 4, imagen 1 de 2 WowWee MiP Robot LED Light Replacement: paso 4, imagen 2 de 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot LED Light Replacement: paso 5, imagen 1 de 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: paso 6, imagen 1 de 2 WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: paso 6, imagen 2 de 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot LED Light Replacement: paso 7, imagen 1 de 3 WowWee MiP Robot LED Light Replacement: paso 7, imagen 2 de 3 WowWee MiP Robot LED Light Replacement: paso 7, imagen 3 de 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot LED Light Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot LED Light Replacement, LED Light: paso 9, imagen 1 de 2 WowWee MiP Robot LED Light Replacement, LED Light: paso 9, imagen 2 de 2
    • Remove the four 7.5mm Phillips #1 screws.
  10. WowWee MiP Robot LED Light Replacement: paso 10, imagen 1 de 2 WowWee MiP Robot LED Light Replacement: paso 10, imagen 2 de 2
    • Carefully pull the motor and motherboard assembly straight out from the base.
    • Be careful not to break the plastic rods that go through the motor assembly and are connect to the shell.
  11. WowWee MiP Robot LED Light Replacement: paso 11, imagen 1 de 1
    • Use the precision tweezers to unplug the bundle of wires.
  12. WowWee MiP Robot LED Light Replacement: paso 12, imagen 1 de 1
    • Slide the head back to separate it from the body.
    • The motherboard does not need to be separated from the head to replace the LED light.
  13. WowWee MiP Robot LED Light Replacement: paso 13, imagen 1 de 1
    • Remove the 7.5mm Phillips #1 screw.
    • The LED light is soldered to the small circuit board.
Conclusión
Una persona más ha completado esta guía.
Courtney
Miembro Desde 02/04/16
236 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-4, Wollert Spring 2016 Miembro de USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 777
