Saltar al contenido principal
Whirlpool Refrigerator Water Inlet Valve Replacement
Qué necesitas
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: paso 2, imagen 1 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: paso 2, imagen 2 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: paso 2, imagen 3 de 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: paso 3, imagen 1 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: paso 3, imagen 2 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: paso 3, imagen 3 de 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: paso 4, imagen 1 de 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: paso 4, imagen 2 de 2
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: paso 5, imagen 1 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: paso 5, imagen 2 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: paso 5, imagen 3 de 3
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: paso 6, imagen 1 de 1
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: paso 7, imagen 1 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: paso 7, imagen 2 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: paso 7, imagen 3 de 3
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: paso 8, imagen 1 de 2 Whirlpool Refrigerator Water Inlet Valve Replacement: paso 8, imagen 2 de 2
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: paso 9, imagen 1 de 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: paso 9, imagen 2 de 2
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: paso 10, imagen 1 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement: paso 10, imagen 2 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement: paso 10, imagen 3 de 3
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: paso 11, imagen 1 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: paso 11, imagen 2 de 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: paso 11, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: paso 12, imagen 1 de 1
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: paso 13, imagen 1 de 1
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 22
Ultimos 7 días: 85
Ultimos 30 días: 269
Todo El Tiempo: 1,589
