Saltar al contenido principal
Whirlpool Refrigerator Water Filter Housing Replacement
Qué necesitas
  1. Whirlpool Refrigerator Water Filter Housing Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: paso 3, imagen 1 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: paso 3, imagen 2 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: paso 3, imagen 3 de 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: paso 4, imagen 1 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: paso 4, imagen 2 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: paso 4, imagen 3 de 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the water filter housing: paso 5, imagen 1 de 1
    • Remove the screw(s) securing the water filter housing.
    • Remove the screw(s) securing the wire harness grounding wire.
  6. Whirlpool Refrigerator Water Filter Housing Replacement, Reposition the housing: paso 6, imagen 1 de 2 Whirlpool Refrigerator Water Filter Housing Replacement, Reposition the housing: paso 6, imagen 2 de 2
    • Pull the housing out of the chassis enough to access its left-hand water connections.
  7. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: paso 7, imagen 1 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: paso 7, imagen 2 de 3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: paso 7, imagen 3 de 3
    • Place a clean and dry rag under the water hoses.
    • Use needle nose pliers, or your fingers, to remove any clips on the top and bottom water hose.
  8. Whirlpool Refrigerator Water Filter Housing Replacement, Disconnect the water hoses: paso 8, imagen 1 de 1
    • Compress the plastic ring near the end of the water hose.
    • While compressing the ring, pull the hose away from the ring to disconnect it.
    • Repeat for the other water hose.
  9. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the housing: paso 9, imagen 1 de 1
    • Remove the water filter housing.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 25
Ultimos 30 días: 92
Todo El Tiempo: 1,073
