Saltar al contenido principal
Whirlpool Refrigerator Thermistor Replacement
Qué necesitas
  1. Whirlpool Refrigerator Thermistor Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Thermistor Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: paso 3, imagen 1 de 2 Whirlpool Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: paso 3, imagen 2 de 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: paso 4, imagen 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: paso 4, imagen 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: paso 4, imagen 3 de 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: paso 5, imagen 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: paso 5, imagen 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: paso 5, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Thermistor Replacement, Remove the assembly: paso 6, imagen 1 de 1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: paso 7, imagen 1 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: paso 7, imagen 2 de 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: paso 7, imagen 3 de 3
    • Disconnect any connectors attached to the thermistor.
  8. Whirlpool Refrigerator Thermistor Replacement, Remove the thermistor: paso 8, imagen 1 de 2 Whirlpool Refrigerator Thermistor Replacement, Remove the thermistor: paso 8, imagen 2 de 2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
  9. Whirlpool Refrigerator Thermistor Replacement, Meter the thermistor: paso 9, imagen 1 de 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 35
Ultimos 30 días: 218
Todo El Tiempo: 1,686
