Saltar al contenido principal
Whirlpool Refrigerator Temperature Control Board Replacement
Qué necesitas
  1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: paso 3, imagen 1 de 2 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: paso 3, imagen 2 de 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: paso 4, imagen 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: paso 4, imagen 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: paso 4, imagen 3 de 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: paso 5, imagen 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: paso 5, imagen 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: paso 5, imagen 3 de 3
    • Disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: paso 6, imagen 1 de 1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: paso 7, imagen 1 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: paso 7, imagen 2 de 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: paso 7, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: paso 8, imagen 1 de 1
    • Pull the temperature control board straight out of its housing to remove it.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 40
Todo El Tiempo: 395
