Saltar al contenido principal
Whirlpool Refrigerator Icemaker Auger Assembly Replacement
Qué necesitas
  1. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker tray: paso 3, imagen 1 de 2 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker tray: paso 3, imagen 2 de 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: paso 4, imagen 1 de 2 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Unfasten the icemaker assembly: paso 4, imagen 2 de 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: paso 5, imagen 1 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: paso 5, imagen 2 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker assembly: paso 5, imagen 3 de 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: paso 6, imagen 1 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: paso 6, imagen 2 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker assembly: paso 6, imagen 3 de 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker assembly: paso 7, imagen 1 de 1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Unfasten the icemaker auger assembly: paso 8, imagen 1 de 1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: paso 9, imagen 1 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: paso 9, imagen 2 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Reposition the icemaker auger assembly: paso 9, imagen 3 de 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: paso 10, imagen 1 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: paso 10, imagen 2 de 3 Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Disconnect the icemaker auger assembly: paso 10, imagen 3 de 3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Icemaker Auger Assembly Replacement, Remove the icemaker auger assembly: paso 11, imagen 1 de 1
    • Remove the icemaker auger assembly.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Miembro Desde 04/14/15
15,876 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
29 Miembros
466 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 146
