Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Whirlpool Refrigerator Icemaker Assembly Replacement
Qué necesitas
  1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: paso 2, imagen 1 de 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: paso 2, imagen 2 de 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: paso 2, imagen 3 de 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: paso 3, imagen 1 de 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: paso 3, imagen 2 de 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: paso 4, imagen 1 de 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: paso 4, imagen 2 de 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: paso 5, imagen 1 de 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: paso 5, imagen 2 de 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: paso 5, imagen 3 de 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: paso 6, imagen 1 de 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: paso 6, imagen 2 de 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: paso 6, imagen 3 de 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: paso 7, imagen 1 de 1
    • Remove the icemaker assembly.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
nicO
Miembro Desde 04/14/15
15,987 Reputación
89 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 44
Ultimos 30 días: 205
Todo El Tiempo: 7,960
